Trailer Hub Lube
neilhendrix
Reidsville N.C.
Heres something I did to my trailers You might be interested in . I fear a breakdown on the Hi-Way because of a bearing failure. Pack by hand first as normal then A couple of pumps every now and then .
Drill and tap 1/8 pipe you`re done
Hope this is Helpful
Neil
maddawg308
826
Appomattox, VA
Huh, pretty cool! Wonder if this could be done on the outside plate of the deuce hubs to allow easier lubing as well?
neilhendrix
Reidsville N.C.
Mike Thanks . I first did this to a 416 I got 25 yrs ago and have done this ever sense. Same as a buddy bearing on a boat trailer ,Well almost. I thought about doing it to the deuce hubs too I don`t think it would hurt a thing. On the trailer you just need to be careful not to blow the seal out the back .
Neil
jwaller
20
Columbia, SC
I would imagine this lubes the outer bearing pretty well but until you pack the space between the inner and outer you dont get much on the inside. I dont think it'd be a good idea to run the hub completely full of GAA.
M543A2
15
Warsaw, Indiana
Many Massey Ferguson farm tractor front hubs have the same system Neil has devised, but they are low speed. The advice about watching blowing out the inner seal is true. I would be careful about it on a duece because then it can get into the brakes if the inner seal is turned inside out by the pressure that can be put out by a grease gun. I note that Neil has two fittings on the cap, is one a pressure relief to limit the pressure applied by the grease gun to a safe level? Yes, the hub has to be full of grease for it to work right. Heat and resulting pressure could build up at prolonged highway speeds. It works on boat trailers, which have a spring in the cap to regulate pressure. If the second fitting on Neil's cap is a spring loaded pressure limiter, then the excess would be vented there. It might get onto the sides of the trailer, but that is better than inverting a seal from the pressure.
Properly hand-packed bearings will run many miles with no problem. I have always been amazed by how little grease they demand. Moisture getting into the grease, or incorrect grease is the biggest culprit in failures.
Regards Marti
neilhendrix
Reidsville N.C.
Marti Thanks. I probably should have left this post Off. Oh well The second fitting is spring loaded and will relieve excess pres. Hand/manual packing is always best for sure. I would not recomend this on a truck , That`s alot of grease I`ve seen alot of trailers sitting on the side of the road because of a bad bearing . Bad /burned/ busted bearin g usually means ruined spindle. Thats a ruff fix on the shoulder of the road . enough said. Maybe this thread will just fade away. Thanks for your input .Have a good day.
Neil
