- 6,426
- 4,976
- 113
- Ft. Lauderdale, Florida
That was here?Sorry I would not use 4inch bolts to do the job anyway.
Nothing I have read makes me think that the flywheel is damaged. Now the man is unbolting the trans to replace the flywheel. It will not hurt to replace.
I could give many reasons for the engine not turning over. And to eliminate any trans problem I would just take out the torque converter bolts, keep it simple, Right.
Allot of assumptions and some good advice also. The flywheel tool, good that will tell him the condition of the flywheel, and if there is a clearance issue, loose bolts, cracked bolt flange. It will help with seeing if the engine is free to rotate, and the symptoms thereof.
I read in another thread about starting at the [top of the hill] when not paying attention to the start, how prophetic.
post #2
https://www.steelsoldiers.com/threads/brake-issues.167598/
