trans prob
tankie88
Redruth,Cornwall,England
About 6 weeks ago i had the trans out of my 85 M1009.Only moved it back 6ins and tilted it back slightly to fit a new flexplate.Now the thing changes from 1st to 2nd normally and quickly into 3rd.It will kick down but not stay in the gear it kicked down to.Also if comeing up a hill it won't change from 3rd to 2nd on it's own,i have to change down manually.Anyone any ideas???????
acetomatoco
9
The modulator line from the vacuum pump, or you may have bent the modulator on a cross member...nuffin serious
badgmc56
Southington Ct.
Is there a kickdown cable going to the trans? If so, check the adjustment at the throttle. I have seen these cables broken also by trying to sneak a flywheel in and not disconnecting them.
