transfer case questions
bugei
reno nevada
is the transfer case in an m39 series 5 ton truck with an lds multifuel, the same as the one in an 800 series truck? i have a 816 wrecker with a "sick" transfer case, and a line on a 5 ton with a multifuel... and would love to make the 800 pound swap never again
thanx
dan
pctrans
19
Bradenton, FL
If you can swing it, swap the x-case AND the tranny. You will be much happier with the multi-tranny in that wrecker.2cents
bugei
reno nevada
ron,
should i interpret that as an unqualified maybe? :)
so all my pto and hydraulic stuff will move over, and the wrecker will live to wreck another day?
i sure hope your right, because when i drag home another green thing, i am gonna be in trouble unless it makes my wrecker wreck
pc,
REALLY? is that a straight bolt for bolt swap? nothing could be worse then the gear splits that the 816 now has. this new 54 is starting to sound better and better.
THANX ALL, you all are contributing to my "justify the 54" campaign
