AECS
- 3
- 18
- Munford, TN
I am installing an external transmission cooler and in my research here ran across a thread that had pictures of an install that had brass adapters at the radiator and at the hard lines so that no cutting was necessary and it could be easily returned to stock. This is what I want! Problem is that I cannot find the thread or pictures again to get the specifics on the fittings I need at the radiator and lines.
If your searchfoo is working better than mine can you put a link here? Or if you have the info I need that would be great! Thanks
AECS
AECS
