Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Mine does as well. A friend of mine who used to rebuild trans says it's probably worn synchromesh. When I gear up I double clutch and it usually gets past the grinding. On the way down sometimes it won't even go into 3rd. At some point I'm just going to bite the bullet and pull the sucker and do a rebuild.
So due to some other threads I've been following I've decided to switch over to Pennzoil 75w90 GL-4. Apparently GL-5 oil is bad for standard tranny's because it eats softer metals such as syncros.
This is a hottly debated topic on the Spicer transmissions. A lot of gl5 is yellow metal safe. The transmission was designed for gl1 and my trans shifts nice with it which is why I use it. All gl1 is safe. I don't know much about the gl4 so I can't comment on it. Good luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
