sargentwolf
- 1
- 18
- st louis/mo
Raised the cab yesterday, found oil had sprayed all over the lower passanger side of the engine. I think it's coming from where the oil sampling port hose attaches to the transmission oil line.
Does anyone know the size fitting so I can just cap it off? I want to remove both the hose and the 90 degree fitting as I think both went bad.
The leak doesn't happen at idle, only when under load in drive. So pretty hard to replicate and being under the engine. Attached a pic of where the oil seems to be coming from.
