Trouble starting in warmer weather....
lindsaym
AK
I have this issue: If I drive my truck for a while, then make a pit-stop somewhere, say for about 20 minutes, then try to start again (when the glow plugs don't fire up), it gives me trouble. It's worse when the outside temp is 35 or up. I have installed the push-button (which works) but it really doesn't seem to be helping. It starts fine in the mornings and fine after work. Any help with this would be appreciated. My wife had to pick me up from Fred Meyer today because I couldn't get the truck to start. Talk about humbling......
GPrez
Mt. Airy, MD
I have the same problem with my 1028, but it does start just not as quick as when it's cold. I was going to put a manual momentary switch to energize the glow plugs like I have on my 1009. Maybe that is not the solution since you already have that.
cpf240
Free in Northern Idaho
Possible bad fuel cutoff solenoid in the IP. Try pouring some water over the IP when this happens, and see if that helps. If so, then consider replacing the fuel cutoff solenoid.
