turbo oil tube
Gun Goober
Claremore, Ok
Gentlemen,
Long time reader, first time question. I've put a new turbo on my Deuce, everything went well until I tried to hook up the oil inlet tube. I tried two from other deuces, then tried to make my own with no success.
My question, where can I get a tube that will fit? ?
Thanks,
1,187
Sounds like a simple question, but We need way more info.
If you have a stock system, your stock tube should fit.
Why does it not fit (add info here)
Gun Goober
Claremore, Ok
The turbo I took off was a growler, I'm thinking of having it rebuilt, no power what so ever from that turbo. The vehicle is a 72, M109A2, 15 K miles, LDT-465-1C.
I put on a whistler from a 68, M35A2. much more power, huge oil leak from the tubes.
What else do you need? I don't want to take up too much of you time.
1,187
I've swapped/removed/replaced/converted quite a few turbos, never had a tube not fit.
In your first post, you did not say it leaked.
I was "guessing" you meant it did not fit (as in, it was the wrong shape or length).
Where is your leak, did you use new gaskets, does the tube end line up, is the flat surface mounting flange parallel?
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Cvrtnick, best start a new thread, that isn't really related to this thread.
Gun Goober, you should be able to make gaskets for the drain tube out of sheet gasket material. The equipment on the trucks you listed should be 100% inter-changable. Can you post a pic or two?
1,187
GR, is that "disco Elmo" (your avatar?)
gimpyrobb
27,787
773
Cincy Ohio
No, thats his illegitimate father, Animal. There is some story about Animal being in a band and traveling around nailing groupies. One story had him donkey kicking a window out while doing one of them.
Gun Goober
Claremore, Ok
The oil inlet has compression fittings on both ends as well as on both the stock tubes I tried. On the tubing I tried to fabricate I used the same type of fittings but could not bend the tube to the correct angles. On the first "stock" tube, the length was good, but the fittings did not seal. The second tube was about 1 1/2 inches too short going into the block connection.
The leak is from the inlet, around the compression fitting.
I have since put the correct compression fittings on copper tubing with about 2 inches of tubing coming out of the fittings. I connected the tubing with a length of fuel line between the block and the top of the turbo. Its not leaking now but I don't like the looks of this "southern engineering" nor do I like something not being correct to the truck.
Again, any help is very appreciated!
gimpyrobb
27,787
773
Cincy Ohio
I wonder if I took one that is sitting in my parts bin to a hydraulic shop, if they could duplicate it. Want me to look into this?
Gun Goober
Claremore, Ok
I guess I could find an hydraulic shop in the Tulsa area. Its another step I can try.
I just thought there would be a hundred of them laying around in a warehouse somewhere.
