turn signal fix
scoutmanadam
richland, washington
my turn signal stopped working on me yesterday. when i got home i went threw the tm's and narrowed it down to the switch on the steering column. now, not wanting to just replace it i took it apart and saw that the groves on the lever itself were worn to the point that they wouldn't push the contacts down enough to complete the circuit. a small bend in the copper contact and it works good as new. hope someone finds this usefull as something to check before buying a new switch.
jrobinson5093
jakin georgia
my turn signals quit working one at a time first the right then the left. i still have not figured out what the problem is. but now i have notice the right side brake light dont work either and ideas?
oddshot
114
Jasper, Georgia
Plus 1.
When I bought mine none of the signals worked ... it turned out to be the flasher unit ... BUT ...
I did a search here and saw that it was a real common problem.
I took my switch apart ... and found that many the contacts in there were green with corrosion. I cleaned them up ... and put it back together.
Then I checked ALL the connections in the aux. lights and found that EVERY ground connection had become loose and several were corroded. I drilled out ALL the rivets holding the ground pig-tails in ALL the housings ... cleaned up the contacts and "screw and nutted" them back together.
Electric boxes like the flasher unit do NOT like the heat and etc from high resistance connections.
oddshot
41cl8m5
30
Littleton, CO
When I got my 2 1/2 ton The lamps worked but I had to manualy move the lever back and forth. Found the ground to the back box in the engine compartment was not made. I moved the wires by hand and it came loose. It looked good before I moved the wire. re-grounded that wire and works like it should.
ARYankee
31
Benton, AR
As far as the turn signal box..... there is a mod where you take the load off the box and add a relay.... The box then controls the relay and only has the load of the relay coil. It's a great and easy mod. I would recommend it to every one.
