Hello to you all,
I have not long had an M35A2 which bought when i sold my jeep as i was finding it very hard to get in and out of it but the REO is so easy for me. Now here in England just having only the red lights at the back of the vehicle is not a good idea
so i purchased a couple of new indicators the same ones as fitted to the front i made up some brackets and mounted them alongside the rear ones
so far so good. now on the driver side i put the signal on and unplugged the wire that set the red one going and connected it to my new amber one .and it worked the side light is good and the brake.
now on doing the same to the other side it will not work i unplugged the red turn wire connected to the new and it works but now the fun started when i turn the side lights on the amber turn lamp won't work but the red light flashes .here is the part that has me baffled when i have the side lights on and run a separate wire from the original turn feed plug to the new lamp it does not work but strangely the red one comes on and flashes .now i cannot begin to wonder how that can happen as the lamps are not connected together apart from being attached to the one bracket.
I would appreciate any help with this .
The reason the body is slightly high as it has been converted to a home from home camper with beds cooker fridge etc and is very cosy for weekends away at shows
