Turn signal relay location
wiggall
151
Lenore, Id.
Where is the Turn signal flasher relay rocated on a 1968 M35A2? and yes I did do a search found out where everything else is located but the turn signal flasher relay. My turn signals do not flash any more.
Thanks
APM215
9
Bradford. ON. Canada.
I had the same thing happen to me. I bought a new relay and installed it and it still didnt work. auaBrake lights worked and running lights worked too. Turned out it was a broken wire in the cannon plug. Sauldered it back together and shrink tubed the end of it and now its working fine.
Good Luck[thumbzup]
