turn signals stopped working when the headlights are off
dma251
15
Arlington, Washington
I took the Deuce down to the carwash today, and I noticed when I left that the trunsignals and brakelights are not functioning without the headlights being turned on. This is new.
Any ideas? Where do I start checking?
mangus580
282
Western NY
There is no fueses in a deuce.
dma, I assume you had the lightswitch in 'brake light' modes when they werent working? Remeber, the 3 lever switch will turn brake and signal lights right off in the OFF position!!
dma251
15
I keep the top lever straight up normally (daytime) and flip it over two clicks (all the way) to the right at night time. Are you saying up is off? It seems like I have always had signals before when the lever was straight up. I never mess with the left lower (brightness) lever.
cranetruck
74
Meadows of Dan, Virginia
With the top lever to the right, two positions (service drive), you can turn your headlights on and off with your lower left lever flipping it from dim to park. You'll have turn signals in all positions of the lower left lever.
mangus580
282
Western NY
DMA, with the top lever straight up, you will not have ANY lights. If you want brakes and signals, go one click to the right, if you want to add headlights, go two clicks right. This is how the switches were meant to work.
If you read the operators manual, it is described in there ;-)
ajg6989
New Smyrna Beach, FL
I had a problem with my right side composite light in the back the hole the cable goes through was rubbing on the cable and causing a short when it moved from a bump here and there.
