turning up the injection pump question
4bogginchevys
rathdrum idaho
is the baseball diamond thing the cover plate below where it says stanadyne in jags post...(2 bolts hold it on)? How do you know if someone else has turned it up, is there some noticable quality of the engine that is bad, without knowing EGT's.... and should I aquire a gasket for this for re-installation of that cover? Thanks:p
btw, If the throttle is mashed than a LITTLE black smoke is all that shows up, dissappears about 2' out of the pipe. Does that resemble a turned up pump or stock?
CUCV85
central/ny
So all the throttle stuff has to come off first right?
Is the home base shaped window in this picture?
Hey what kind of contraption
you got going on there!?
[thumbzup] ok Modification, I said it - now do tell...
custom fuel return?
Matt65
Alabama
My truck runs great.
Of course, I would love to get more power out of her. Will the IP adjustment create a noticeable power increase? Are there any negative effects of doing so? Does a How To with pictures exist for this?
And back to my initial statement - Should I just leave well enough alone?
