erasedhammer
- 56
- 28
- Maryland
I was changing the oil on my geared hubs after some off roading and as soon as the drain plug came out, I knew something was going to be broken/worn in the hub. Oil came out grey, which as far as I can tell is water mixed in with the oil. In addition to the water oil small amount of metal bits came out with the oil, which I can only assume was from the spur gears.
The culprit of the problem was the vent line got stuck on one of the cable clamps and pulled of the hub in a turn. Water came right in.
Now with this kind of damage, I have to ask which would be a better option. Rebuild the hub? Or replace it all together?
If replace the hub, where could I get one? All I can find online is hummer hubs or 12k hubs for 1500+. Bluehummer outfitters has a rebuild kit, which looks like it might be cheaper but I don't know what else in the hub is damaged.
