germanrifle
- 0
- 0
- Texas
Hey folks. I want to mount a 2 or a 4 place, vic-1 sys in my m998. Would like to see some pics of the sys mounted. Pics of it mounted have been hard to come by.
I built an "extension" for the standard VIC mount that's under the radio deck. It's a foot long piece of 5" x 3/8" steel flat stock. I drilled it to match the holes for the the AM-1780 in the VIC mount, then bolted through the AM-1780, the extension, and the mount. I drilled the end to match the C-2298 and bolted it to the extension. It's thick enough that the crew station doesn't wobble, and it doesn't intrude on the passenger space much at all.Ty. So what is the far right box attached to?
Got my Radios here, they are spendy though, reconditioned and look factory new. https://www.recodefense.com/about.html Here's what I previously had in mine, but I have the taller dual tray setup and plate for Vic1 now to put in, when I get the energy.Hey fellas where are you findin serviceable A M 1780 and RT 524s I am looking for one radio and two AM 1780s
NICE that's exactly what I'm doing except I'm putting a 2297 commanders box on the left.
6 meter band afaik ham license.just curious, besides military authenticity, and the cool factor, if the rt-524 works- fcc license or not- what do you use it for? talking to whom?
Can you expand on the tach mount?Pictures from around the Cab showing the install.
View attachment 689411View attachment 689410View attachment 689409View attachment 689412View attachment 689413View attachment 689414View attachment 689415
I do have a MX777 Surge suppressor mounted horizontally behind the Amplifier that is fed from the battery and then an individual power cable to the VIC-1 and then to the Radios. I also have all the cables to hook up the KY-57's to the radio bases as well. You can also see that I mounted the tachometer on the side of the radio enclisure and then mounted a DAGAR mount on the top that holds my iPhone perfectly.
