Vietnam Skull Shift Knob and Modern Light Switch
Wintermute
Woodinville, WA
Well, figured I'd put up some pictures of the vietnam skull shift knob installed (I think it looks really good).
I also won an ebay auction for a modern light switch (push button with LED indicators) that I recieved and installed tonight. It's awsome! :) Honestly, so much easier to see what I'm selecting than the three lever switch is.
Here's the skull shift knob:
And here's the new light switch:
Switch Off:
Switch On:
Switch with headlights/driving lights on:
--Wintermute
ARYankee
31
Benton, AR
Cool. I like it. I'm going to mount a grenade for my shifter knob. I also like the light switch. Was it plug and play or did you have to do some modifications?
Wintermute
Woodinville, WA
The grenade shift knob would be cool. I got my shift knob from here:
House O' Speed Hot Rod Store Home Page
Just search for "Leasure" (J. Leasure is the maker of the shift knob I got...he makes a bunch of different ones. I also really like the Doughboy one).
Here's a couple other places that carry his shift knobs:
Hot Rod Speed Company
Results for "Joshua Leasure" Shift Knobs
Installing the switch was pretty much plug and play. Disconnect your batteries, remove the screws from the old connector, unscrew the electrical connector from the back, connect the electrical connector to the new switch, screw the switch back into the dash, then connect the ground line for the new switch off to a good ground (I connected mine to the same ground screw used for my solid state flasher module) and finally, reconnect your batteries and you're good to go.
--Wintermute
redthegreendog
clarkesville, GA
Be careful with the digital switch. we had problems with them in our refitted M998 HUMMV. They like to burn up wiring in the older ones that came with the 3 lever switch. they all had to be changed back to the old switch. not sure why my be a voltage problem.:?
Wintermute
Woodinville, WA
yeah, paint is still what it was painted by the Idaho Dept. of Land Management. It was a brush firetruck before I got it. Won't be stripped and back to CARC until next summer.
--Wintermute
