VIN Help
FMJ
37
Las Cruces, NM
Sorry if this belongs somewhere else.....did a couple of searches no luck.
I am looking at this truck, 1GCHD34J4GF316102, 2 questions, does it have a NP205 case , and does it have the limited slip front diff?
Thanks in advance!
acetomatoco
9
1GC is Chevrolet Truck
H is 9-10K GVW with Hydraulic Brakes
D3 is military truck 4 x 4 one ton
4 is body type-2 door cab
J is Chev 6.2 Diesel
4 is the check digit
G is the model year
F is the paint code
and the next six are the production sequence number beginning at 100001
to answer your questions, you must look at the options sticker in the glove box or on the top of the driver's fender liner under the hood.... The RPO codes are usually 3 digits like AA3 is for tinted glass...
FMJ
37
Las Cruces, NM
Would the NSN help at all....the truck is not near to my location.
NSN INFORMATION 2320-01-090-7893
Says that its a 1028......
FMJ
37
Las Cruces, NM
Re: RE: VIN Help
GM72K10 said:
He meant F is the plant code not paint code
What is the NSN of your 1028A1?, if its the same as the one I posted, what T-case and front axle config (open or limited slip) do you have?
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
RE: Re: RE: VIN Help
It is probably an M1028 VIN, if you can trust the listing. The NSN is not a CUCV NSN, it is a generic 1-ton truck NSN. The DRMO site must have been lazy.
This truck WILL NOT have the NP205. It has the NP208. But, it *should* have a Dana Trac-Lok in the front axle, if it's an M1028.
Only the M1031 had the NP205. Since the M1028A1 is a converted M1031, it does too. As does the M1028A2 (a dually converted M1028A1).
CUCVFAN
47
Jarrettsville, MD
I should add that I've never confirmed it through looking at the original contract, but I don't believe there were any factory produced M1028A1's, which is why I say it isn't an M1028A1, thus no NP205...
GM72K10
68
Bucks County, Pa.
My M1028a1 is sort of an M1031, it has the NP205, the sticker in the glove box lists it as a cab and chassis. The door has M1028. It was (when I bought the truck) a contact service unit. I put a pickup bed on it from a M1008 parts truck.
CUCVFAN
47
Jarrettsville, MD
If it was a contact maintenance truck, it was an M1031, hence the 205 and the cab/chassis RPO. The M1028A1/A2 were MWO's for an M1031.
The door plate is really pretty meanigless. My M1009 is an M1028, according to the door and my M1028A1 was an M1009, according to the door. They each had a door from another truck put on them at some point in military life.
CARNAC
The Envelope Please.
717
College Station, TX
The VIN comes back as a M1028 with the following info:
nsn nomen serial num reg num date of mfg
2320 011275077 M1028 J4GF316102 NG1XSK 1986
Last unit: 178TH EN BN HHC HVY DIV
Nomenclature:TRUCK CARGO 1-1/4T
Model: M1028
Serial Number: J4GF316102 Registration Number: NG1XSK
Year of Mfg:1986
Manufacturer: 93219
Contract Number:DAAE07-82-C-4060
Miles at Turn-in: 23334
FMJ
37
Las Cruces, NM
Thanks!
Model: M1028
Year of Mfg:1986
Manufacturer: 93219
GM72K10
68
Bucks County, Pa.
Ok,
My M1028a1 was "converted" 07/92 into a M1028a1 TM01 Shelter Carrier at "TEAD". The NSN number originally was 2320-01-133-5368 (M1031 C & C), the modified truck then had a new NSN, 2320-01-158-0820. The glove box option for the NP205 is: 7MF4.
Good Luck in your search.
GM72K10
68
Bucks County, Pa.
FYI:
M1008A1 TRUCK CARGO TAC 5/4 TON 4X4 W/COMMO KIT 2320-01-123-2671
M1028 TRUCK CARGO TAC 5/4 TON 4X4 SHELTER CARRIER W/E 2320-01-127-5077
M1008 TRUCK CARGO TAC 5/4 TON 4X4 W/E 2320-01-123-6827
M1028A1 TRUCK CARGO TAC 5/4 TON SHELTER CARRIER 4X4 W/PTO 2320-01-158-0820
