Voltmeter bulb
llong66
kokomo, In
I am getting ready to order new LEDs for my dashlights and need a little help, I am going through superbrightled.com and had no problem finding the 168/194 style bulb for everything. The problem is the -20p tm lists the voltmeter bulb as 1445 and I see no replacement for it. Is there another number I need to be using? I have seen other threads where ppl replaced this bulb with an LED but I dont know which one. Thanks!
Warthog
244
OKC, OK
Do not use LEDs for the GEN lights. Your alternators will not work.
I'll check the voltmeter bulb when I get to work.
combatmech
Carrollton, Texas
Be sure to disconnect your batteries BEFORE you take your dash apart. Bad things can happen when loose "hot" wires come into contact with things they shouldn't. It happend to me and made my already problematic electrical system worse.
