VRC-64 help needed
Steamynachos
Calgary Alberta
Can a RT-524 be hooked up to a am-2060 and the Vic-1 all at the same time? All I can find is that the Am-2060 powers the Vic-1 but can the RT-524 also be used in the power circuit through the Mt-1029 tray? so you can receive from both radios at the same time and transmit on one or the other? the reason I ask as I would like to mount the RT-524 beside my Am2060 with an Prc-77 on it and have the ability to use them both on the Vic-1 system at the same time. Sorry if this seems confusing I know I am confused what would this setup be known as ? :?
Steamynachos
Calgary Alberta
the AM-2060 and the RT-524 both need a MT-1029 tray to work but can I run one wire from the battery to the 524's tray then a power wire from it to the am2060's tray then a wirefrom that one to the Vic-1 all in a daisy chain? and have them all work together or is this to much power though the trays? and how does the audio cable connect or are they the same cables?
emmado22
168
Mid Hudson Valley NY
Yes, you can daisy chain the Mt1029's and then to the "master VIC 1 box" no problem.... They were designed to do that. Can thelp you with the rest of the ausio stuff though..
CARNAC
The Envelope Please.
712
College Station, TX
I want to make sure I'm reading this correct just for clarification since I am looking at putting 2 radios and an aux into my 1009 in the future.
The intent here is to go:
power - cable - MT-1029 - cable - MT-1029 - cable - AM1780 - cable - C2298
w/RT-524 w/AM-2060
w/RT841
ONTOS66
Franklin, NJ
Several manuals are available in pdf in the reference section, as an example:
TM 11-5815-332-15 RADIO TELETYPEWRITER SET, AN/VSC-3
TM 11-5820-401-10-1-HR Handreceipt Manual, VRC-12 Series Radios
TM 11-5820-401-20-1 Organizational Maintenance, VRC-12 Series Radios
TM 11-5820-401-20-2 Organizational Maintenance, VRC-12 Series Radios w/ intercom
TM 11-5830-340-30 Direct Support Maintenance AN/VIC-1(V)
TM 11-5915-223-12-HR MX-7778/GRC Hand Receipt Manual
TM 11-5915-223-24P SUPPRESSOR ELECTRICAL, TRANSIENT MX-7778/GRC
TM 11-5915-224-24P SUPPRESSOR ELECTRICAL, TRANSIENT MX-7778A/GRC
As well as information on installing radios in CUCV, etc.
Let your fingers do the walking through the reference section.
