Waiting for the wait light??
mudman
10
Carson City, NV
Well today while waiting for the wait light to go out, I realized I had not heard the relay working. What is the best unit to by for replace ment. Also I'm doing the dog head relay a well. I have two new relays for the volt meter and **** forgot what the other one was for. anyway do you know where the two relays might be. I think they are near the starter relay under the dash. thanks for any help!!
doghead
4 Star General /Moderator
1,187
NY
Sound is not the way to diagnose a relay, use a meter!
ST-85 relay, best choice.
Relays are under the dash, to the right of the radio panel.
Let's work on Tech Manuals and Searching, next. (glad to see you were able to figure out how to post a new thread!)
mudman
10
Carson City, NV
GP relay bad??
Ok heres the scoop on my GP relay (**** this is frustrating).. when the key is truned, on there is a "clunk" at the relay. Problem is that there is 25 volts on one side and nothing on the other. Question is....Drum roll....... "Can the relay be bad even if there is a clunk when the key is turned on?? I have no power to the GP's at all. 12.5 ohms between the to smaller posts. What gives??:deadhorse:
Thanks,
Ken
doghead
1,187
NY
I merged your last thread, with this one. Please continue your threads, so we know what's going on. Otherwise, we'll just ask the same questions and give you the same answers.
If you have no voltage out of the relay, it is probably bad. Do you have 12v on one small terminal? The light blue wire is just grounded by the controller to activate the relay.
You could bench test your relay
You could also follow the troubleshooting instructions in the TM.
doghead
1,187
NY
No, the blue wire gets grounded.
The other small terminal should have 12v with the key on.
doghead
1,187
NY
OK, now go out, with the key on, and use a jumperwire and ground the terminal with the light blue wire on it. Test for voltage coming out (lower large terminal) of the relay like that.
mudman
10
Carson City, NV
OK here is the latest. With the jumper wire hooked up to the blue wire, key on, and grounded, I could smell the GP's working, so I jumped in a now I have "FIRE IN THE HOLE"!!!
So What does all this mean, I hope the relay is bad and not the card, as it is new also. **** I feel better already..Better go have a beer now!!!
doghead
1,187
NY
Well, if you have a new card, then I would suspect your temp sensor may be bad. Might just be unplugged.
doghead
1,187
NY
Did you locate the temp sensor? Was it connected? I posted a picture of it, above(from the TM).
You can test it and see if it has continuity.
mudman
10
Carson City, NV
No I have not a clue where it might be. I see some people saying it's on the back of the motor..But where? I have run outa light and there is 3 " on new snow on the ground right now.
I gotta say Doghead, that you have been a lot of help this evening. I hope to get back to this tomorrow.
mudman
10
Carson City, NV
Right on Ralbelt, you're handier than a pocket on a T-shirt.... Is it the one with the yellow wire or the red wire.?? You and Doghead are all right in y book!!
