WANTED - Junk Fuel Injector Nozzle
houdel
11
Chase, MI
Does anyone have a junk fuel injector nozzle they can part with? Doesn't make any difference if the nozzles are plugged or not, just as long as it will seal to the cylinder head. I need one to make an adapter for my cylinder balance tester. I'll have to take it apart and pull out all the internal components anyhow so I can drill out nozzle tip to get max air flow through the tester. I would appreciate if someone out there has a junker nozzle they can send me. You can PM or email me if you have one handy. Thanks, Lee
Crazyguyla
124
Altus, OK
I have an injector that's has some rust on the tip, but it's currently in New Orleans, La :( Next time I'm home, I can get it.
houdel
11
Chase, MI
That would probably help. I might need a couple anyhow in case I screw one up, plus I need to figure out how to make a cylinder compression adapter as well. I can buy a compression adapter that "almost fits" for about $40, one that fits just right the first time would be a lot better.
Marcus - Is there anyone an home who could locate your rusted injector and ship it out? In case I cant find one earlier? I'd be glad to work out some sort of suitable reimbursement. Course, its so cold and snowy out here I won't be doing too much work outside anyhow!
Thanks, Lee
