Waste Oil Storage
dm22630
42
Front Royal, VA 22630
I am amazed at how EASY it is to get FREE used motor oil!! :mrgreen:
I dont really want a bunch of 55 gallon drums stacking up at my house, so what is the best kind of tank for bulk storage or waste oil? Are the 275 gallon HHO tanks the best to use? Or would it be better to get a 1000+ gallon buried tank?
275 Gallon HHO tanks are free/cheap around here.....but I think the neighbors may know something is up if they start piling up.
Thanks!
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
I use HHO tanks, mounted about 10 feet up, on a industrial pallet rack. Pump the oil in (in my case filtered) and then when I need it, open the valve on the bottom.
doghead
4 Star General /Moderator
1,193
NY
I would avoid the underground tank idea. Used 275 gal HHO tanks are cheap and easy.
doghead
1,193
NY
Open all the holes available and use a garden hose to rinse out any sludge. If your careful you can do it with less than 5 gals of water. Let it dry for several days in the sun. Then you have one 5 gal bucket of junk to get rid of, it will evaporate eventually, down to just the sludge or find a place to dispose of it.(throw it on a bonfire)
wreckerman893
Possum Connoisseur
15,647
2,141
I laid my 275 gal "tote" on it's side and used a pressure washer to clean out the gunk inside.
I have a portable 12 volt pump with filter on it. I use it to pump WVO and WMO and it works like a charm. Got it from Northern Hydrolics.
When you pump out of a container make sure to stop about 5 inches from the bottom to keep from getting all the sediment and water out. I have a strainer on my intake hose to keep from sucking large objects in that would hurt the pump.
Keep in mind that a full tote weighs around 2400 pounds...make sure that if you elevate it the stand can handle the weight.
Also keep them out of the sun....the plastic will become brittle after a while.
DanMartin
17
Hillsboro, Oregon (USA)
I've heard of people using decommissioned (ie: free) home heating oil tanks (the free-standing kind) for WVO/WMO storage too. Just make sure you can contain any spills if they leak...
area52
San Bernardino CA
I would use a steel tank in decent shape with no rust issues. Elevate it and put it on the south side to let the sun heat it as much as possible that way you can drain any water/sludge that settles out.
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Had to pressure wash out the tanks I use also, they had a lot of sludge in them. Came out nice and clean inside.
