Weight of M105 trailer bed
samsimpson
Corpus Christi, TX
Anyone know the approx weight of just the bed of a M105 trailer?
I want to do some repairs to the underside of a bed and was wondering if it would be too heavy to a couple of guys to pick up and flip over (detached from the frame of coarse).
swbradley1
Modertator
1,566
Dayton, OH
I really want pics of two guys picking one up.
Gimp and I are moving one and it will take the backhoe to move it around and get it off the frame.
BKubu
1,096
Gaithersburg, MD
I am not sure the exact weight, but it is far too heavy for two guys to lift and flip. I just moved a bed and a CBC shelter from one chassis to another and it was hairy since I did not have a forklift or a crane. We used jacks and blocking under all corners.
rcflyer70
Lancaster, Kansas
The bed has to be over 800lbs. I put one on its side last year with my 371 bobcat (will lift around 800lbs with someone standing on the back for counterweight). It put the bed on its side but would not lift it.
samsimpson
Corpus Christi, TX
That is what I figured, but was hoping it wasn't that heavy. Guess I will use an A frame to lift it. If it was more like 500lb wouldn't be an issue. Thanks for the input guys.
samsimpson
Corpus Christi, TX
Well the bonus of having more then one thread for a particular question or issue is the likeliness that new members will find it easier. The search here isn't all that great, especially when there might be only 1 thread about the topic.
1,814
The search engine works fine, the operators aren't all that great. I searched "M105 bed weight" in the trailer forum and got 8 hits. I searched title only and this thread was number one, the one Wayne posted was number 3. Took 10 seconds.
samsimpson
Corpus Christi, TX
When I searched after seeing that there was already one (I searched before obviously but only checked the first 5 results), it was #9 for me, with mine being #1.
The 5 I checked were completely unrelated, if the top 5 aren't close people will tend to think the rest aren't either since it should return the best matched threads first, the most relevent to the least relevent. At least that is how my site (RamchargerCentral.Com) works.
SteveKuhn
Hasbrouck Heights NJ
I have (2) 105s - one mid-60s and a more modern galvanized. I'll bet there's a difference in weight, so I think Gimp's answer is the best working one. I wouldn't want my rig too close to the top end of a low number. I'd say it depends on the trailer, and the older the heavier. But my bathroom scale's is off a bit.
Steve
WestPointDad
Peoria, Az.
OK...Thank you guys for your information.
I will post my progress on the modification as it goes.
RC
Steve
3dAngus
101
Perry, Ga.
I've always wondered the exact weight. Did any search indicate the exact weight, or just approximate.
Next time I scrap a M 105, I'll pull the bed off separate and weigh it to the pound. should be doing one next month.
