galeo7171
- 0
- 16
- Cumming, Ga
Installed new injectors and return lines. Bled the air out and started the truck. I got it to idle and I noticed fuel pouring out at the passenger rear injector (closest to firewall). It appeared that fuel was leaking at the return line. One of the return nozzles is capped off and the other one goes to the injector the right of it. The truck started to stumble and want to die which I assumed was from the fuel leak. Weird part is, if I pull the return line off the injector (the line that is connected to the next injector) the truck returns to normal idle. Obviously there is still fuel leaking out of the now disconnected return line, but the the truck idles fine. While the truck was still idling, I hooked the return line back up to the injector and the truck starts to idle rough and die. I'm clueless of course at what is causing this, any ideas?
