M1028A1ShelterCarrier
- 65
- 28
- Mammoth Lakes Ca.
So the other day I decided to due some easy preventive maintenance and swapped the radiator. While taking of the oil cooler lines off the radiator, one of the hard lines crumbled. A hour job turned into a day project. To get the truck running until the replacement hard line arrived, I used hydraulic hose (IT MIGHT OF KINKED ALLOWING OIL PRESSURE BUILDUP). A couple of days later, I noticed a loud ticking that that goes up and down with the engine regardless of what gear I am in. The noise is coming around the oil pan/ bell housing so I think it could be the oil pump (low mileage though). I put the factory hard line back in and the noise is still there. The low oil pressure light has not came on. The engine is running normal minus the noise! Any ideas? Is there a way to check this theory?
