tm america
- 23
- 38
- merrillville in
i think just reg motor oil or even better yet airtool oil
Is there a portion of the TM that shows this procedure being done? Sounds like a good idea.on oiling the airpack. Especially in cold weather. Pop out the plug on the rear or in my case the j pipe and shoot in some airtool oil. Should at least keep the piston moving. Should probably do this 2-3 times a year.
Just my 2 cents.
C.T.
air tool oil, can be found at any parts store, lowes, home depot.What type of oil should be used to lube this..?
Thanks,
Andy.
it's mounted to the master cylinder on the back and should use an ounce or two at most. 1-2 times per year.Being new what does the air pack look like and where is it. But there is a square plug that needs to be removed to lube it? And how much air tool oil do I squirt in?
