What does your M35A3 Tach at WOT ?
doghead
4 Star General /Moderator
1,193
NY
What does the engine data sticker on the valve cover say?
I thought max rpm was 2900.
lonegunman
Eastern, Washington
Data plate on the engine is the max RPM from Caterpillar. Mine said 2925 and when Cat verified the tac, they revved it to max and it held 2927 rpm.
The Army -10 says 2750 max rpm when operating the truck, my truck has a bolt under the gas pedal that is set to limit things to around 2700-2750rpm on level ground.
If you revved 3000 rpm all the way home, you are testing th eengine quite a bit. When I first got the truck, I pegged the tac on a couple of downhill runs and made 60 or so mph. Itis not something I'd do constantly to a truck I liked.
Over-revving the engine on the way home has resulted in a few A2 guys suffering engine failures in the last few weeks, no doubt someone with an A3 will join them in the engine search at some point. Running 3K rpms for long periods might end up being expensive, you might want to rethink that idea.
The truck itself has a whopping 56mph recommended top speed which is close to the Army recommended 2750rpm. They run smoothest at around 48-50mph for most people. This is the 2500-2600 rpm range.
