What is this bracket for?
SMOKEWAGON66
21
California
Thank you.
Were these fit to all trucks or just those that had gun rings?
Are gun ring assemblies available anywhere?
I think most trucks had this one bracket. The full mounts however are a seperate assebly. I dont know where you can find one. Ask around here..im sure someone knows where one is or has one to sell.
135gmc
St Paul/MN
There are usually two pairs of U bolts on the rear of the cab to mount the other two legs to a ring mount - if not the U bolts, then you should be able to find the holes. Ring mounts run into money real fast - you need to track down the ring, the three legs, the trolley (that holds your MG), the ammunition tray, the front clamp that holds your '50 cal's barrel in place, a dummy M2 MG, and a canvas cover for the MG. Depending on what you wind up with, it will probably run at least $ 2500-3000. It will be cheaper if you find a cut ring and weld it back together, but the trolleys are getting real scarce if you want to use Vietnam-era pieces.
mcmullag
13
Colorado Springs, CO region
and don't forget to obtain the large sheet of metal that gets riveted across the lower backside of the cab for additional bracing. Search or google about ring mount on deuce and you will find all you want to know.
