What parts on a 939 series work with m35a2?
After a lot of searching the forums I decided to start a thread listing which parts off a 939 series truck would work on our m35 trucks. Please reply if you can add any. I haven't tried any of these but after researching found the following...
Will fit;
Doors and door hardware
Steering wheel
Horn and button hardware
Heater system with modification
Headlights, Tail lights, Turn Lights, and Marker lights their hosings and brackets
Gauges (Not sure about speedo/tachs)
Battery holders
Battery cables
Batteries and the terminals
Turn Signal Lever
3 Lever light switch
Power Switch
Indicator Lights on dash
Driver Seat
Windshield hardware will fit, but not the actual windshields
Cargo cover with modification (sized for deuce bed)
Bows and uprights for the cargo bed but not the troop seats
Tires will fit in dual configure (11.00R20) but not the wheels
Glad hands
NATO slave port
Lug nuts
Thimbles
Trailer plug cover
Air governor
Bulbs
Axle drain plugs
Mud flap bolts
Shackles
Bridge plate
Alternator (check pulley size)
Tailgate (must be same style as replacement dropside to dropside etc.)
Will not fit;
Front Bumper (Frame to tall and not the same)
Obviously the engine, transmission, transfer case, brakes, and axle components
Most if not all body and cab body
Fuel tank (won't fit and no sender in tank)
1,169
What is a 900 series truck?
1,169
That's a 939 series truck.
goldneagle
872
Slidell, LA
Driver seat will fit.
Batteries will fit.
Battery holders will fit.
Battery Cables will fit.
Power switch will fit.
Panel lights will fit.
Windshield hardware will fit, but not the actual windshields.
Light switch will fit.
Turn signal lever will fit.
Tail Lights and front lights will fit.
Headlights will fit.
Tires will fit if 11.00-20's
Bows for cargo area will fit. Not the cargo cover unless modified.
Glad hands will fit.
NATO receptacle will fit.
Possible the bumperettes will fit.
That's all I could think of.
1,169
Lug nuts, thimbles, batteries, terminals, trailer plug cover, headlights, air governor, horns, brake fluid, light bulbs, axle drain plugs, , mud flap bolts, lift shackles, bridge plate.
1,169
Since the OP asked about 900 series trucks, and they do not exist, maybe if they did they would use BFS.
goldneagle
872
Slidell, LA
LOL
Learn something new every day! Wish it would let me edit the thread title but oh well. Great list might be small stuff but the list might help someone out..
Ask doghead to edit the title for you. He will do it when he is done breaking your chops. (trying to keep it clean)
I am no expert with the 939 trucks but some parts that I am curious maybe someone will know if they would work/fit (even with slight modifications) are;
Fuel tank pump?
Fuel tank sender?
Fuel tank?
Alternator?
Tailgate on the cargo bed?
He can bust my chops all day long, I will be the first to admit my mistakes and laugh at myself.. @Doghead Please ;)
1,169
Fuel tank pump?
Fuel tank sender?
Fuel tank?
Alternator?
There is no in-tank fuel pump on an M939 series truck.
Maybe
No
Yes (may need a different pulley)
Yes, dropside to dropside, or regular bed to regular bed
