What seals should I do?
motormayhem
Tucson, AZ
Ok so i am going to put my transmission into another case tomorrow and am thinking of what else I can do while I am under there. I plan on giving it a new front pump seal, rear crank seal, and the rear seal on tranny. When I go to get these parts what do I tell them? Can I say I need something for an 84' civvy with a 6.2 or do I need something different for the m1009's?
Thanks,
Miles
kennyw
Stones Throw from Reiter, WA
Tell them you need seals for a TH400 (turbo 400) with an NP208 tcase. They can be found in any 1 ton mid 80's Chevy K30 4x4. Don't use a K5 if they want make/model info since that would get you 700R4 parts if they look up a civilian model.
Front pump seal, front pump gasket, transmission pan gasket and filter, input/output seals for the NP208 and the rear main seal on the motor would be the minimum.
