Wheel bearing lock nut socket size M211
firefox
General
1,844
52
Berkeley CA
I measured the axle nut flat to flat as 3 3/8 inch.
However I could only find a socket size of 3 1/2 inch. Will this work, or is there a 3 3/8 inch socket out there some place?
Any help would be appreciated,
Bruce
blybrook
Fairbanks, AK
I agree, that price is way up there, but McMaster Carr is really proud of their products. It is a 1" drive impact socket, the only other one I could come across quickly was a 3/4" drive thin walled socket that was going for over the price of the 1"!
You may be able to modify a 3-1/2" socket with some shim stock to get the job done. I have done this in the past as well. Some 1/16" steel plate pieces (or heavy gauge material) and you are all set.
319
Lieutenant
3,347
58
Michigan
firefox, you should be able to get the OTC from your local NAPA. If you cannot find one locally, PM me.
I'll check tomorrow to see if I have one on the shelf and PM you the price.
