who's got a fuel pump??
Rocco
Lynchburg VA
RE: who
That means im going to have to cut the copper fuel lines and tie it in?
Well whats going on is my fuel pump never worked
and since i have changed the fuel filters I will be driving and it gets air in the line and it turns off
But im guessing if I get the pump working it will not do that anymore?
Why all of a sudden it keeps acting up like this?
This is the second time I have changed the filters and now I have a problem.
The first time I never had a problem. but air keeps getting in,its not as bad this time.
but 3weeks ago it was getting a lot more air in it
I replaced the filter gaskets and its got better.
but today im driving down the highway and it shut down not fun.
Rocco
Lynchburg VA
RE: who
RPM's 1500-2000.
Its not the cans,
four different times I have messed with them.
engine transfer pump? Where is this located?
I will have wait till monday to get the pump.
so im gonna get NAPA# P4603HD.
Thanks for the help.
cranetruck
94
Meadows of Dan, Virginia
RE: Re: RE: who
Make sure you bleed the air out of your lines and filters after changing anything. It's the little valve on top of the secondary/final filter bracket. Air in the system will shut you down at low rpms....you probably did this, but may be worth mentioning anyway...
