Why doesn't the cucv have something like a voltage protection diode?
TexAndy
Bee County, Texas
Like the 939 series trucks, I mean. Those trucks have a voltage protection box with some big diodes in them to prevent back emf from damaging alternators, ABS computer, etc...
So why doesn't the cucv have something like that? And would the cucv benefit from something like that?
I ask because a friend just came down and helped me fix my starter. Which is to say, he pretty much did all the work. Keith_J is a **** of a nice guy.
We had to rotate the studs on the solenoid for them to make good contact against the copper plate part that gets pushed by the coil. The flat contacts were scorched and etched from arcing.
Could back emf have caused that arcing? Or is that just normal wear and tear? This starter only has about 7,000 miles on it.
tim292stro
40
S.F. Bay Area/California
PCB's costs money add complexity, mostly prevent hooking up batteries backwards.
Sounds like normal wear and tear, if your batteries were low when started.
That said, a 12/24V split system has its own quirks that would benefit from a diode protecting the 12V loads from reverse polarity voltage when the lower battery's ground is disconnected. Nothing says you can't add it after the fact :beer:
