Some more pointers for future help.
Turns out that if you remove the three mounting bolts first, you can grap the assembly and push it up to the top where you can easily access the two nuts without taking the hood off. If you pop it off and it drops down you can easily get it back up with a screwdriver through the motor opening. It is pretty easy to get it off and the new one back on just using your fingers after you loosen it up. I got plenty of practise since I forgot to transfer the gasket that goes in the hole where the arm goes thru.
The really funny part is when I went to put fluid in the resovoir, I noticed that the suction tube had fallen off.
I have a feeling that that was the problem all along,
but it was many years ago when I first looked at it.
Well, it works great now.
Bruce
