Wire Spec
Artisan
227
CDA Idaho
What is the proper way to spec wire / how do I call out this;
Wire
Color = BLACK
2 Wire in one round casing
5/8" OD
#4 Stranded Wires (high amp usage, a small winch)
Mil Spec?
I want it to be very plyable, easy to coil, so FINE Stranding yes? )
The connector I am using is an IIT CANNON Bayonet Plug #24-9S
( CA3106E24-9SB )It is a 2 socket Amphenol type
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
#4 is rated up to 70amps. Do you know what the amp draw is for the winch?
Yes, fine strand, probably should look into welding leads.
quickfarms
24
Orange Junction, CA
You need to look at the spec for the particular wire. Read the manufacturers tables. The capacity varies depending on the insulation type and number of conductors.
Artisan
227
CDA Idaho
I am electrical ignorant.
Tables? I never work w/ wire, welding leads sounds about right.
Who makes that stuff and I will research.
Artisan
227
CDA Idaho
Thanx Gimp but I am looking for 1 cable that has 2 "Conductors" inside it.
The Conductors need to be #4, stranded.
The outside of the cable needs to be ROUND to fit my plug perfectly.
The cable needs to be BLACK w/ an OD of real close to 5/8" .
Somewhere there is probably a manufacturer that has a WIRE SPECIFIER program
where you just punch in your parameters and it spits out a P/N
Artisan
227
CDA Idaho
MtnSnow
14
NSL, UT
Why would you want to use VCTF since it's rated for 70°C & for use in dry locations? Where as the SOOW or even STOW is rated for 90*C & 105C* as well as "outdoor" rated...
Artisan
227
CDA Idaho
Ah HA!
Starting to get some place here.
Thank U Mtn
This wire I need will go from the crane winch to a "box" maybe even
a Fat 50 ammo can so a 10' piece is more than enough, from there
it is powered by a Slave Cable so we should be A-Ok on the length vs amps issue.
Artisan
227
CDA Idaho
The site Mtn sent us to has THIS wire. It is 3 conductor, not two, I still
am looking, they want $7.00 a foot for that stuff too!
I also saw this on that website;
SOOW Jacket is rated to 600 Volts. Jacket is Oil resistant and Outdoor Weather resistant. Typically used for outdoor extra hard usage applications. Jacket is Oil resistant and constructed from NBR/PVC Rubber. The conductors are annealed (soft) copper and are insulated with NBR/PVC Rubber. Flexible cord is rated to 90°C for use in outdoor locations. The Wire colors are in compliance with North American Color Code (NACC). UL 62 and UL 1581.
cUL rated for outdoor use. Advantage of NBR/PVC SOOW jacket over typical rubber SOOW is it provides a smooth surface for sliding when in movement and it picks up less debris. Disadvantage is at very cold temperatures it becomes more rigid than rubber. UL General-Use guidance for Ampacity of current-carrying conductors is contingent upon length (50 Feet or less) and number of current carrying conductors.
I will be in cold w/ it, to "0F" , I probably will not be in "Very Cold" w/ it "-0F"
gimpyrobb
27,785
747
Cincy Ohio
I said that simply from a materials construction stand point. I didn't realize the deficiencies it had!
MtnSnow
14
NSL, UT
:) Gotcha Just was wondering if there was something new to it from what I had known....Always looking to learn more :)
