Roger Friedrich
- 1
- 8
- Cape Girardeau,MO
I have a 62 M37 that I've been trying to get the stoplights to work. The 3 lever switch has been replaced and the stop light switch at the master cylinder and I know these can be bad but the other light work ok when I flip the switches.
My problem is with the area of the wiring harness that I guess was put into the harness for the turn signal relay, which I don't have. I can used a jumper and can get the stoplights to light up from the right inner fender and at the wires at the turn signal harness location. At this location I have 22B, 22-460, 22-461, 22,22 and two other wire that has no tags on then. I have a wiring diagram for the turn signal set up and to start I have traced the 75 stop light feed to the brake switch, which has power. The wiring shows 75 A stop light switch going back to the 3 lever switch then 22B service stop coming out and going to the turn signal harness and then there 22-460 and 22-461 should feed back to the stoplights but when I hook then together the stoplights don't work when you push the pedal down.
I was wonder if I need to put in the turn signal system or does anyone have any ideals
