Wndshield Washer Performance?
WARWAG
Excellent thread. I need to replace the worn out pump for sure with a more modern one. Also I want ti install an intermittent wiper function in the process. Last but not least my wiper motor has started making a squeaking noise thats starting to get on my nerves! Anyone else have this problem?
408
Colo.
Nope, just click .... click .... click. Used to be the same, followed with, wait .... trying to squirt, little squirt, squirt barely.
And that's after removing the resistor on the pump and swapping the passenger and driver's side lines. Another be done with it CUCV mod.
wayne pick
Valley Cottage NY
Don, Here's what I did to my truck. I installed a washer tank from a 2000 s10 blazer. It has two pumps. I plumed it so each of the nozzles are fed from one pump. It pours washer fluid over the windshield! Wire the pumps into the existing circuit on the wiper motor.2.jpg
scottladdy
10
CT
To fix mine, I removed pump assembly from the firewall. Removed the cover from the upper gear assembly. Cleaned and lubed with white lithium grease as the old grease had solidified. I cleaned and re-gaped the parking circuit switch.
Then, I reassembled and used ANCO #6106 washer pump repair kit for $7 at RockAuto.com.
Have done this on two trucks and the washers and wipers now work as new.
Hasdrubal
Vancouver BC
Yes, mine had started squeaking also, don't know if you could disassemble it and lubricate the bearings. I replaced it with a new OEM unit for $117.
donalloy1
Martinez Ca
Don, Here's what I did to my truck. I installed a washer tank from a 2000 s10 blazer. It has two pumps. I plumed it so each of the nozzles are fed from one pump. It pours washer fluid over the windshield! Wire the pumps into the existing circuit on the wiper motor.View attachment 465080
That's a interesting approach wayne pick. That tank looks like a monster! All done in the interest of safety. Must have a clean windscreen!
donalloy1
Martinez Ca
scottladdy, thought about removing pump from motor. Afraid I might damage in process. Looks like a couple flimsy plastic locking clips are all that holds together? Gather you have done a couple times. Must be fairly robust?
Clean and lube part makes sense. re-gap parking circuit switch part has me kind of baffled. Can you give us a little more detail and or a picture of where you did this and purpose?
scottladdy
10
CT
Check the procedure in the -34 section 10-8 "Wiper Motor Repair". Starts on page 10-26.
Hope this helps ...
wayne pick
Valley Cottage NY
Thanks Don, the pumps work far better than the original tank setup, and holds a full gallon of fluid. As you can see, I fabricated up an L bracket where the original tank was for my plow pump, so I had to figure out a way to relocate the tank.
I had a parts s10 blazer which I took the bucket seats out of for the 1031, and figured I could retrofit the washer tank also. It fits perfectly in that corner spot. The plumbing and wiring was really simple. Nothing fancy, I just used a test light to figure out the circuit.
