jerseyjeep2003
- 2
- 0
- Gloucester City NJ
My truck has developed wobbly wheel syndrome, or as some say...death wobble. At 35 mph I get so much wobble that I can't even hold the steering wheel, moves about 2" either way. So OK, I figure maybe tie rod ends, king pins or wheel bearings. I found some play in the king pin (.020 up and down, that is .006 out of spec), wheel bearings good (minimally loose) tie rod ends good and tight, steering box not too bad. So I replace king pin bushings and repack and snug up bearings, checked for bent rim....yes. I made a jig to use my dial indicator to measure the bend after "sledgehammering" the steel into submission. I got the total runout on the rim (not mounted to the truck) to .010. I THOUGHT this would have solved the problem.....nope, still wobbles. I am running 16x20 Mich's with tubes. Could the tube be "shifted" in the rim, or could the tire hve a bad belt as some passenger car tires get? Even though the tires are directional, I am thinking of switching them left to right just to see if the wobble follows the tire. Any thoughts may or may not be helpful, but are definately appreciated.
