wonder what this means?
Tackettr
Edmond/OK
I would guess this has something to do with the military switching to DOT5 brake fluid, but that is just a guess. I would like the know your findings also.
1,823
Apparently there were some MCs in the system that weren't TACOM approved. Depending on the level of maintenance, try TM 9-2320-361-20 and TM 9-2320-361-34.
jasonjc
291
Gravette Ar.
The deuce does not use a "Hydravac". vac= vacuum, the deuce uses presure. Does the map box door fit another truck? like a M37 or m715?? Or is TACOM just useing the wrong wording??
m16ty
218
Dickson,TN
If your truck has a hydravac it would be one of a kind. Don't know where you'd get your vaccum to run a hydravac if you have a multifuel.
number9
Lexington, KY
My truck has the same sticker on the glovebox and also came out of Toole Army Depot. I found this thread while searching trying to find out what it meant.
Anyone have an answer?
BugEyeBear
Eastern Georgia
Perhaps they used a "standard" sticker to simply indicate that an approved M/C & booster has been installed??
(i.e didn't have one that said "hydrapress"??)
number9
Lexington, KY
Okay, but what I am after to find out is "TACOM approved" of what? What is different, approved, whatever about the master cylinder than one's that aren't? What was the issue, problem that this change was made and is significant enough to have a big yellow sticker placed on the dash to notify the occupants that this master cylinder is "TACOM Approved"?
number9
Lexington, KY
Does anyone have answers about what these stckers mean? Surely some of the MV experts on here know what this means or some info / history?
