Wrecker rear drag winch brake drum
MAZ537
23
EU
Hello guys,
I have six 45k rear winches for rebuild ,all the brake drums are badly pitted , I have clean one on a lathe but I have to remove at least 2mm from it to have a nice smooth surface.The wear limit is very tight on these (from 5.503" to 5.497")...So can I still use them ?
Thank you!
gimpyrobb
dumpsterlandingfromorbit!
27,787
773
Cincy Ohio
Worst comes to worst, make a sleeve for it. Make it small enough to have an interference fit(heat it up to install) or plug weld it and machine flat.
MAZ537
23
EU
This sounds good , but the brake drum is cast iron and I do not know if the sleeve is doable ?
These things are almost impossible to find !!!
