Yanmar L70 Diesel Kit for MEP-016
tmuenster
111
31
TN
I purchased a few of the Yanmar L70 Diesel engine refit kits for the gasoline powered version of the MEP-016 generators. The kits come with all the parts to convert the generators to run on the Yanmar L70 engine.
The engines have electric start and are set up for a 24v system. Does anyone know if it is possible to convert these to a 12v system? I would like to use them to power a small boat and I prefer to use 12v if possible.
Sent from my iPad using Tapatalk
Isaac-1
51
SW, Louisiana
I have a MEP-016D and as I recall the entire 24V electrical system consists of the starter, which will generally have enough excess power to crank on a well charged 12V battery. There is no onboard alternator or magneto that charges the cranking battery, unlike the MEP-016B, etc.
Scoobyshep
2,012
Florida
Id be surprised if 12 volt would spin a 24 volt starter fast enough.
Sent from my SM-G973U using Tapatalk
Tow4
669
Orlando, FL
I have one of the small 2kw generators with a Yanmar engine. The starter was bad when I picked it up so I replaced it with a 12 volt starter.
There is no battery charging circuit and no on board battery. There is a slave connector for starter power. I took a pair of jumper cables and put a slave connector on one end so I can start the engine with whatever power source that is available.
