212sparky
- 38
- 48
- Monroe/ Ohio
I purchased an MEP-004a on Dec 29 2011. It started up after about 10 seconds of cranking. to previous owner had not used it that often and from time to time he said it was stubborn to get started. I went to start it today after putting brand new batteries and all it does is crank. i am getting white smoke and when i first hit the start switch it cranks over kicks out that starter then nothing it just cranks over and over. i have fuel to the filters and the Injector Pump. i plan tomorrow to crack the lines at the injectors and check flow. If i pill the injectors is their any thing that i need to watch out for like gaskets?
Thanks,
Rob
Thanks,
Rob
