Mep-016b hertz guage readings
Donaldjerome
Pinckney, mi
When I start my mep-016b up I let it warm up then dial it in to 60 hzs via the fine throttle knob.. I plugged our chop saw in the shop to the convienance outlet when I start the saw up and put a load on the generator the hertz guage pegs out all the way to the right 64-65 hertz. Is something out of adjustment or should I be thinking the guage is bad? I have 2 mep-016b gennys and they both do this. I know household current is 60 hz how much can you deviate from this?
derf
13
LA
I think sometimes power tools will generate interference. I think if you dial in the freq and the RPM of the gen doesn't change then you should still be generating 60Hz. Do you have an external Hz meter you can test with? Kill-A-Watt?
coyote62ny
-1
sherburne new york
one thing to always remember with mep gen sets is dont ever run the engine at less than 60 hertz start and shut down at 60 hertz or you will blow the a.c voltage regulator set the throttle to 60 hertz and leave it there.
ETN550
9
Knoxville, TN
That is good advice. I bought the Kill a Watt and it has come in very handy. As far as your gage goes the sending unit is a black box on the right side panel inside the control box behind the output switch. My gage was acting funny, drifting, and through advice of people here I replaced the capacitors on the board in that black box. That fixed the problem.
Regarding the fact that the speed should not fall too low as damage to the voltage regulator can result, I did the following which works good. Where the throttle cable ends on the engine there are two screws with lock nuts that limit the travel of the lever that the cable pulls on. One screw limits the high speed the other the low speed. Simply run the set at 55hz and adjust the low speed screw to just contact the lever then run the set at 65 hz and adjust the high speed screw so it just touches the lever. Now you will have plenty of adjustment around 60 hz and never have an issue underspeeding the unit and damaging the regulator.
sky5031
camp roberts, ar
mep016b/ mep021b
Does anyone here know what the part number is of the engine control board
used on mep016b (diesel engine) system, or even parts list for this board.
Anyone got a spare? Does anyone have any pictures of this board installed,
or of board/ sky5031
