Just boguht my first deuce, what can you tell me about it?
226
Felton, DE
I dunno im a truck driver, all of my trucks whistle, i just assumed the whistler was a more distinct whistler. its not quiet, but most in videos ive watched seemed louder. i thought the only way to tell was if it was a 1C motor.
The knob on top of the ebrake lever or the adjuster under the truck by the drum?
deuceaid
Banned
915
149
Yucaipa CA
You can also tighten down the cable under the truck ( off the back of the tee case) in addition to the parking brake handle if its too loose. And from time to time You will need "soldier B " to help You, because some things are just too big for one person to do safely or at all. Also I would get cable operated air tank drains if it doesnt have them, and drain the air tanks all the time.
226
Felton, DE
Where are the air tanks? I glanced around when i was under it but forgot to search for them.
I did notice there was a hissing when the truck was shut off for a few minutes then a realse of air and it stopped. it would repeat when cycling the accessory switch. Is this an automatic moisture drain of some sort as on new trucks?
dikwks
Suffolk VA
Like everybody said, get your manuals, do your checks, be safe. But hold on Dude, it's gonna be a helluva lot of fun!!:beer: Congratulations, and my sympathies, both at the same time.
derby
10
S.E. MI.
The hissing you here is the air regulator on the firewall.
There are two turbos used on the LDS like the LDT one is loud and the other is not as loud. The owner knocked cash off for selling you a truck with an LDS? Do You feel Guilty.......:-o
226
Felton, DE
I guess maybe it is loud? I am not sure. The owner said he didnt know much about it, i didnt know much other than it didnt match the engine codes i was looking for as a whistler. I didnt know, he didnt know. i thought it might be the problematic continental engine but i wasnt sure. Neither of us knew haha. i still paid plenty for it, and the hard top is held on with a pipe wrench in the front for now. What clamps held on the origional removable hard tops? I couldnt find anywhere anything would have mounted to hold it. I will just make some.
Jeepjake
Bend, OR
dikwks is right, I got mine almost a year ago. I had a perma-grin on the 200 mile recovery. This is the most precious thing I own, I love this truck. Huge, amazingly useful for hauling all sorts of whatever you got! (as long as you have patience, they aint fast! :D )
I swapped my D turbo out for a C turbo on my LDT (Im sick like that) love the scream, hearing protection required!!!!!
JeepJake
Felton, DE
Oh i see the difference, i will have to check it out when i pick it up, i wouldnt say the turbo was annoyingly loud or anything although i have a 5" straight pipe exhaust on my duramax. still straight pipe powerstrokes are much much louder than duramaxs though.
I have read something about needing a pyrometer when this engine is swapped with the old air box? Is that true? I will be doing reaerch all week, i am just trying to power pack some knowledge from you guys before i pick it up. I really appreciate all the replaies.
Thanks guys!
Heavysteven
11
Hickory Flat Ga
I have made some video's on YouTube going over some parts of the deuce. Here is one.
[media]http://www.youtube.com/watch?v=SZ-vkMESHXg&feature=youtube_gdata_player[/media]
Jeepjake
Bend, OR
Thanks guys!
Im a noob myself, I may have misguided you, the two turbos shown in my previous post are installed in an LDT-465, I am unfamiliar with the LDS installations.
-jeep
Vintage iron
Falmouth Ma.
I have a complete heater for your truck with controls and ducts too. $250. +shipping. PM me if you are thinking of adding one. I can put a more powerful engine in your truck too. good luck with your truck
charlietango
20
Winnipeg
congrats man, keep the TM as your new bible.. things come up, don't get discouraged when they do. Some jobs are better left to HD truck repair shops with specialty tools. It helps to pre-determine what sections of the TM they might need to help with the process and print them out. These trucks shake, leak, grunt and love it. If its not leaking there might be something wrong :shock: . Just be realistic basically is what I'm getting at. these are old dogs and parts wear out or are already worn.
226
Felton, DE
Yeah there were no bolts on the windsheild and the windhseild folds forward. i would agree it must have been a soft top. its bolted behind the seats. I will just add some nice latches to make the top easily removable then. i didnt buy it to be orgional or anything, im going to use it and have fun in it.
