crazywelder72
- 2
- 0
- Winchester Ma
About 2 days ago when I was going up a little hill in 4th gear, I noticed the rpm's started to shoot up a bit without noticing it pull any harder. As soon as I felt it I let off the pedal and everything was normal again. Was this a sign of the clutch slipping? It has happened a few times since then.
Also I have noticed I have had a tremendous amount of trouble downshifting in the past few days also? It wants to grind the gears. Up shifting isn't a problem at all. Is this a clutch issue also?
i just got exhausted looking thru tm's. I didn't have much luck. TM 9-2320-209-20-3-1 chapter 3 (page 67). I was looking for clutch plate info and all this was linkages. I need to reread it.
Any step-by-step threads? looking for any helpful info, maybe I can adjust it to keep it from slipping? (but where and how)
