Vet89
- 3
- 0
- Cedar Rapids, Iowa
Hello again and thank you in advance?
I believe I have a fuseable link issue (reference http://www.steelsoldiers.com/cucv/93453-if-not-when-occured-starter-relay.html)
Thanks to Dependable, I researched fusable links through searches here and beyond.
I pulled my starter (fun with no jackstands or lift!) and saw the ignition wire and wire to the battery. I used a multimeter and tested the line that I believe should be activated when I turn the ignition (the smaller of the two wires connected to the starter). No power. A strong indicator that this is the problem. I tried to trace the wire but it goes up into the plastic casing with other wires. I'd like to find the endpoint without undoing all the plastic casing if possible and test the wires end point for power.
Looking at the wiring diagram - I see the ignition wire connected to the solenoid. What I am not sure about is looking at the connection point on the other side of the wiring diagram and how it relates to the actual engine components.
In the photo, the purple wire leaves the terminal labeled 3 PPL something to a little box shaped thing (yep, I am on the low end of being a shade tree mechanic, but I enjoy learning new things!). Rather than start yanking on it and inviting Mr. Murphy to come along and help me more, I thought I would ask. Photo is from Warthog's efforts.
Any pointers for where this actually is?
