Deuce Rear Lug Stud Question
hangfire
Joplin, Missouri
I have a question that I have not found a definitive answer to reading the TM's, Searching the Forum, Goggling, Binging, Yahooing, You tube, So I am now asking the experts here.
Is it possible to change out 1 busted rear left lug stud with out pulling the axle and hub?
In the schematic’s I just can not tell if the hub must come off or not.
I will thank you now for your help to my question.
Thanks, Mike
3dAngus
101
Perry, Ga.
New studs for your M35A2 are $7.50 from Eric's surplus. I got four in today for my parts kit. Be sure to specify the left or the right as they are reverse threaded on the other side.
I don't know how you would press them out without removal of the hub.
mikey
39
Lake Como, PA
No, gotta remove the hub.
The good news is you can't find a better guide than this for removing your hub and pressing the stud out:
Hub Flip
hangfire
Joplin, Missouri
Thanks, I was thinking that I would have to pull the Hub but was hoping for a short cut. I have th estud seals and gasket on hand to do the job.
Thanks, Mike
