Transmission Jingle
jime
Centerburg, OH
Sorry to disappoint, but this is NOT a song about a transmission. It's about a high pitched jingle I hear when in motion from the transmission area. It's kinda like some chains clanging together. It's always made the sound, and it's not real loud and can barely be heard over the other sounds. I notice it the most when wearing hearing protection that filters out the lower frequencies. Anything to worry about? Everything seems to function normally.
skinnedknuckles
Janesville Wisconsin
I once had a high pitched "ringing" Clark transmission in a single axle 5 yard dump truck. As it turns out I pulled it and found , if I remember right , a cracked gear on the countershaft. It cracked radially about half way around the gear and up to the teeth. The engine in front of it was a 8.3 Detroit diesel V-8. Good luck
Paul in Janesville Wis
DieselBob
15
Arnold Maryland
Just a thought but have you checked the rear engine mounts and transfer case mounts to see if the mount bolts are still tight. If the rubber insulators compress much it would let the bolts and washers jingle from vibration.
rattlecan6104
Oak Harbor, WA
I had a sound like that once... found out it was a bearing in the T-case that was causing, drained the T-case oil and found more shavings than you can shake a stick at.
BEASTMASTER
148
Burgaw, N.C.
i have the same noise in my 5 ton. inside the jackshaft there is a large washer i think it's a grease retainer, but anyway ,the thing is loose and makes a rattling noise. nothing to worry about.
