Wiring Problems - M1028
NMerenda
Rochester, NY
Well the first issue is the (what I believe is a fusible link) in the first picture is fried. I could use a part number or maybe there is another way to "fuse" these two wires together. The second issue is there is a wire with a ring terminal on the end hanging down near the bumper on the driver's side. I have no idea what it is or where it's supposed to go.
Warthog
242
OKC, OK
Read the Fusible Link sticky and watch some youtubes on cutting and splicing. Parts are available at napa.
Fusable links are designed for a purpose. That is to "protect" your electrical system from catching fire.
that wire is your 12v feed for the entire 12v system.
the second pic is a ground wire for the headlight. Reattach on top of the radiator support near the overflow tank
NMerenda
Rochester, NY
Just got under front bumper, there is already a wire going to the radiator support by the coolant overflow. Anywhere else that wire could go? It's a black wire.
Warthog
242
OKC, OK
It is a ground and if it reaches it also mounts with the other black wires on the radiator support.
